I am just playing around with a Corsair H50, taking temp readings with different fan speeds before I begin to overclock.
I have an additional fan I can add to the fray and I am thinking of setting it up in a push/pull fashion.
The 2 fans available to me are:
Noctua NF-P12 -54.32CFM with a static pressure of 1.68 mm H2O
Akasa AK174CB-4BLB -59.05CFM with a static pressure of 3.57mm H20
What are peoples thoughts on mixing the differently specced fans. would I be better putting the higher static pressure fan pushing air into the radiator and the lower Noctua pulling air out, or vice-verca?
Also would using the Noctua impact performance over say another fan at equal static pressure to the Akasa?
Cheers
Cheers
