9 Aug 2011 at 18:32 #1 ltnmzh ltnmzh Associate Joined 6 Aug 2011 Posts 480 Hi guys, Sorry for a stupid question. Can I use one slice of memeory with my H67 MoBo? I remember in the old days you would need to pair two....
9 Aug 2011 at 18:35 #2 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 It's best to use pairs as this enables dual channel mode for better performance. But you can use one stick and it will work fine in single channel mode.
9 Aug 2011 at 18:42 #3 ltnmzh ltnmzh Associate OP Joined 6 Aug 2011 Posts 480 Thanks! So tri-channel CPUs should use 3 slices for best performance?
9 Aug 2011 at 18:47 #4 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 ltnmzh said: Thanks! So tri-channel CPUs should use 3 slices for best performance? Click to expand... CPU's with a triple channel memory controller using the X58 chipset use sticks in threes (3 or 6) for best performance. Yes is the simple answer
10 Aug 2011 at 00:51 #5 Justintime Justintime Soldato Joined 24 Jul 2006 Posts 8,876 Location Hoddesdon, London, UK Thanks for a good giggle mate, never heard it referred to as slices
10 Aug 2011 at 11:50 #6 ltnmzh ltnmzh Associate OP Joined 6 Aug 2011 Posts 480 Justintime said: Thanks for a good giggle mate, never heard it referred to as slices Click to expand... Pizza terms For The Win!
