- 14 Apr 2011
should i be worried about the noise of the h70 cooler, or should i comprimise little bit of performance with noise and go 4 the new h60. oc 2600k @ 4.2-4.5
I've got a H70, it is loud, so bought some headphones, problem solved.should i be worried about the noise of the h70 cooler, or should i comprimise little bit of performance with noise and go 4 the new h60. oc 2600k @ 4.2-4.5
