Hi I will be building a new PC with the Corsair 600t White Case.
I was just wondering what would be best to go for? Is there much of a performance difference between the two?
If I go for the H100 I will have to place the radiator fans on top of the case as they wont fit inside due to motherboard being to close as shown in this pic of someone else's build
But with the H80 there would be no issues so I am just wondering if the performance difference is so small it might be worth me going for the H80?
What do you reckon? Also the top fans will be covered and out of sight with the H100 so I am not worried about that.
