Hacksaw Blade Effect In BF2 :(
No.
I have every setting in BF2 Video set to max. EVERYTHING :)
I even set ATi CCC To max everything.
Jimi said:
Well judging by the screenshot that was posted he's either got AA on 2x or not at all, that's what's 'causing the jaggies, look at the bottom of the chopper.
As far as I am aware antialiasing doesn't affect shadows at all in Battlefield 2. In fact, I don't think I have ever seen a game where it does. :confused:
It does with some shadows, static objects are the ones that have crappy shadows, things like trees and buildings.
I have heard of this before and I am 90% certain that there is a fix. I don't what it is but if you Google search I think you will find it. :)
If memory serves, it is a driver issue.
Odd, it's mostly vehicles with crappy shadows for me. Tanks/cars/planes that sort of thing.
Traditional AA only works on solid objects/terrain constructed from polygons. Most game shadows are just another material effect (like bump mapping), applied after the physical scene has been rendered, so AA doesn't apply.
Soft shadows are a result of more complex shadow effects, not AA.
That's what I thought too. :confused:
It's having dynamic shadows set to medium or lower.
Set the to high and the shadows do come up to scratch but saying that dynamic shadows at full is a pretty high overhead by it's nature.
Hmm Where is the Dynamic Shadow setting ?
and are you saying i should enable them ?
Many Thanks So far lads, your great :D
