Thanks for the comments guys
Simon, I'd love to see how well yours handles. Even with ****** bushes I'm yet to feel even a hint of bodyroll. It just feels so planted.
On the way back, coming off the M60 onto the M61 there's a lovely tight bend which I would normally take at around 55-60 and be on the edge. I looked at my speedo mid-corner to see it reading 75mph
It had plenty more left in it!
In fact, the difference is that much, that I've actually had quite bad understeer while cornering
Obviously I'm taking corners faster because the roll is less and my crappy P6000's can't cope.
I'm going to get either low profile Eagle F1's for these wheels and refurbish them, or I might even try and pick up some 16" Hairpins. I think they'll suit the car pretty well.
Aaron, at the end of the first day, Cableguy did try to remove the lower arm so that he could take it with him and drill the bolt out. The furthest bolt from the hub came out fine... but the bolt that held the arm to the hub, the same thing was happening. The bush has welded itself onto the bolt which would have caused it to snap if we'd tried to undo it.
