I have problems with keeping heat out of my case as my PC is under the stairs. So there is very little air low I already have two desk fans on the floor at the back to draw cool ish air in from the house at ground level.
But my video card gets hot around 80c it will run upto 95c so I am ok with not damaging it but the case is right next to me & thats a lot of hot air getting blown out of it.
My CPU is over clocked to 4Ghz & sometimes if it gets to hot in my little room it will crash once aweek this may happen.
Water cooling of CPU or GPU is out of the question as me & water do not mix & am always getting water leaks in the house it's just me so no water on the components . Also I have little room to get at the PC.
There is also no room for a Air con unit as this would be the best fix.
So this is my plain but would it work?
This is my case Silverstone Fortress 2 FT02B-W Windowed Gaming Case http://www.overclockers.co.uk/showproduct.php?prodid=CA-067-SV&groupid=701&catid=7&subcat=1092
It's the one with the 90° degree motherboard mounting so the GPU hot air gets blown out of the top of the case. The case has three massive 180mm fans at the base blowing air into the case (in my case warm air)
So what if I fixed a 360 Radiator at the bottom on top of the three fans, it will fit.
Then have a Hailea Ultra Titan 500 Water Chiller
http://www.overclockers.co.uk/showproduct.php?prodid=WC-003-HL&groupid=962&catid=2140&subcat=
Pumping cool water in to the Radiator & that cool air is then blown into the case?
I know I said no to water cooling but this is at the base of the case away from doing any water damage. whats the worse that could happen other then the Rad getting a leak & the fans spitting water all over my M/B
Would it work?
Is there a better option?
Thanks
Would it work?
Thanks
