Half-life 2 not loading anymore
2 May 2004
I'm not sure when or why it stopped loading, no hardware or software has changed on my PC.
The loading bar gets about 4 blocks from the end, then just stops :(
I've tried deleting all Half-life 2 content and reinstalling it with no luck (that includes removing all the caches and the ClientRegistry.blob file)
HL2.exe and Steam are allowed in my firewall.
I've also tried multiple different save games, they all do the same thing so they're not corrupt.
CSS works perfectly.
Any ideas on a fix?
Thanks,
Craig.
Going to guess you on Vista 64 as had same problem recently myself.
Go into Steam, clcik Half Life 2, click properties at the bottom.
Set Launch Options and enter -32bit
Hope that works
D:\Steam\SteamApps\USERNAME\half-life 2\hl2\SAVE
Seems to be where mine are, wasn't far through when happened to me, and had deleted my saved games trying to fix problem.
Done that :(
Even reinstalled Half-life 2.
Meh I hope I'm not gonna have to delete my entire Steam folder to get it sorted, that'd just be a pain - would take ages to update, only running 300Kbps here :/
tried steam forums?
steam client update?
posisbly update sound/gfx/chipset drivers (heavy i know, but better than full steam reinstall)
A 12.49MB steam client update was released yesterday, I'll download that now. Hopefully it'll fix the problem.
Also, as far as I know my sound/graphics/chipset are all up to date, I only updated them a few weeks ago. Half-life 2 has been working perfectly since those updates, it only stopped working randomly recently :(
[Edit]
Nope, update didn't help.
