Half Life 2 problems
22 Jan 2008
Installed the orange box a few weeks ago, everythings been running quite well untill i play TF2. I can play for 10mins or 2 Hours the time doesn't seem to affect it, but when i exit the game my computer just hangs. I can Ctrl+Alt+Del out then i try to end the process but still does nothing, i have to hit the power switch. It Also happens in Ep. 2.
Anyone else had this problem and found a fix ?
Specs in case it helps, Q6600 - 2gig ram - 8800GT - Vista 32bit
Appreciate any help.
I have a similar issue with Vista - every time I exit the game it tells me that it has stopped working and tries to find a solution but it doesn't hang the whole system.
Have you checked Vista's Event Viewer?
