Halo 2 Problems
29 Apr 2007
London
I cant install Halo 2
The autorun works and tell it to install. Then the autorun thing clocses and nothing else happens. Has anyone solved/know why this problem happens?
It's better if you edit rather than keep posting. Now calm down its been less than 10 mins since you created this thread.
You're using Vista right?
I also dont have a setup.exe file. The only other thing I can think of is to copy the disk to your hard drive and try running it from there.
Again, please use edit. Seeing your sig about 5 times on one page isn't good for the eyes.
Try either returning it and getting a replacement, or try it on a different computer? Could be your DVD drive.
tried it on a different computer. Seems other people on google are having similar problems but no solution. Must be drivers. Oh well
It only works on Vista, Microsoft = fail.
Microsoft do not equal fail you moron. All games have problems when they first come out and just because this one is made by Ms, people start having a go.
I was having problems with my copy Ross, but it was crashing issues when I would join a Live game.
I tried a lot of things but weirdly enough the thing that fixed it was my video card drivers (I downloaded the newest ones from ATi). I would expect MS will be bringing out an update very soon as there are a few people having problems :)
They fail because they made a potentially good game exclusively for Vista, when it could be running on ME... It's sad.
