Halo 2....
15 Aug 2003
Essex
I shall be buying this on the PC when its out to refresh the story (only completed it once when released) and to get some points..
however i have an xbox copy ehre and wondered if anyone wants to play some multiplayer tonight?
If you wanna play it on xbox live you will need to be quick because when the new maps are released for it on April 17th you will not be able to play matchmaking without them. Every play list from April 21st onwards will include them so to play matchmaking your going to be forced to buy the maps otherwise your going to be stuck with custom games only :(
I would play but I suck since I havent played for months and Im way to stressed out atm to handle it and I would end up losing it everytime I die :/
Is there anything i need right now to play?
Its never touched my 360 before so....
What cable you got your 360 hooked up with? If its VGA its a right pain in the ass to update since you need to constantly switch between composite and VGA because of the 50Hz compatability. So if you got VGA (not sure about component since I dont use it) you will need to use the composite to patch it to the latest version, since the old xbox update system doesnt seem to support 60Hz for some reason even though the game will play in 60hz :/
You will also need the Halo 2 map pack (which is also downloaded from the old update system) theres 9 of them and they are free now.
Hahaha you always do anyway ;)
I have Halo2 still in its wrapper. I got it to see what all the hype was about but stil havent got round to it. I'd try it online but would end up getting creamed by people like Alrik who have mastered it for years.
im a n00b to we can play together :D
Im serious Im on breaking point atm thats why I wont be on GoW for a few days. Something has really wound me up this week and I cant work out what. Its been recommended that I laugh my ass off to help relieve some of it :p
Also I would recommend it Danny its a brilliant multi-player game and still has life in it yet until Halo 3 comes along, again though I doubt you will like it since its similar to GoW, but 10x better and when you've got a group of great people to play with its a right laugh.
Nor have I played it in multiplayer (or in SP for 2 years!).
Me, you and McDaniel should have a laugh :).
I'm game tonight but I know you're only getting it to be a score whore :p
Christ mate they're only computer games! I've never known anyone to take them that seriously =/
Probably removing the weapons slide on GOW and losing your advantage. ;)
Hope you get straight soon :)
If your a noob too then McD I might unwrap it if a few Ocukers wanna play as easy game.
Its something else thats happened and games are just making it worse
I dont care about weapon slide either danny (only cos I couldnt use it ;)) Though its still possible to use it through a different method.
My apologies, hope it gets better soon mate.
Oh and miccy p I can't view the pic you sent me for some reason :s
If your all thinking of playing it would be recommened to update it as soon as you get home since the maps take ages to download and the latest update corrupted mine so I had to do them again. So if you wait till 8 tonight it will take you about an hour or so, just a warning
