Putting a mirror up in the lounge on the chimney breast, so plenty of solid brick.
The mirror has two hook/loops on the back, I believe they're called strap hooks.
Do I need a matching J Hook to hang them off, like seen in https://www.ebay.co.uk/itm/SECURE-H...NGING-KIT-HOOKS-HANGERS-FITTINGS/202365546486 or can I just hang it off screws?
If either is suitable, what size plugs should I be using? Brown Rawl plugs?
