Happened again Ryzen systen (not OC) Keeps Locking Up Help??
What dose the screen show when it locks up/just before? do you have a normal image thats just forzen or dose it look strange?
do you have an old GPU you can try as it would be much simpler to rule out the GPU by dropping any in thats know good and looping a benchmark for a while.
i see the game but its frozen thats it and i cant do anything but to force shut down
also its not the gpu i had a different gpu before this one and it did it then too
In this situation I would be leaving everything to auto in BIOS (boost and everything), if stable then set Mem to DOCP profile, if not stable then slightly increase DRAM voltage.
If only unstable when setting Mem to 2400 - give it slightly move volts
Just grabbed the manual for the board, there are settings for soc voltage and couldn't find memory timings but they're mentioned they can be changed in advanced mode.
