Hi guys. I'll be finishing my build within the next couple of days. I have two hard drives i'll be using. One is a new WD Green 750gb, the other is an old 160gb WD sata 7200rpm. I intend to use the 160gb for the OS and games/programs, and the 750gb for documents and images/video/music. The problem is the 160gb is currently full of files i want to transfer to the 750gb drive. So is the only way to do this to install Windows on the 750gb, copy all of the files that I want from the 160gb to the 750gb, then format the 160gb ready for windows, and then uninstall W7 from the 750gb drive? Will I be able to install windows twice on two different drives within such a short period of time?
Also, hoiw would you recommend i partition my 160gb drive, which i intend to use for the OS and games? And how about the 750gb drive, would that be better split into partitions?
Just wondering whats the best way to go about all of this! I also have an old IDE drive i need to rescue files from
Apologies, this was meant for the general hardware forum!
