Hello All,
I wanted to have a little rant about HDD's. When you look at components such as processors or graphics cards, you can physically see that over the years they have progressed leaps and bounds. Yet HDD's are still the bottleneck that they've always been. It annoys me. OK, on paper they obviously have progressed but it winds me up that after i upgraded to an i7, 6GB RAM, Ati 4850, my PC is still clunking away like it used to. Why ? Because HDD's are just not capable to pushing the data through fast enough. I've got 2 WD 250GB drives in a raid 0 setup and while i realise they're not the newest things around, im also aware that replacing them with new drives will probably make little or no real difference. I might get better numbers in a benchmark utility such as HD Tach but ultimately, i doubt it'll make any real world difference. Do you think that there will ever be a time when HDD technology catches up with the rest of the component world (other than in a capacity sense) ? SSD drives look promising but is also very new, expensive and probably has it's share of teething problems.
