Hard Drive Caddy Compatibility Question
20 Jun 2012
Polegate, East Sussex
Hi Guys,
Someone from my work wants the HDD from their old PC taken out and then used as an external one.
I know this is possible with the use of a HDD caddy, but wanted to check if this is compatible with all the caddys available now.
eSyStor Callisto 80GB ATA
Any help would be really appreciated.
Thanks
Edit - Ok after a little bit of research it appears I need an older caddy that can take ATA/PATA not Sata! Are these still readily available?
