Hard drive causing computer to cut power and reboot
30 Oct 2012
this has been doing this ever since i built my computer, i purchased my western digital sata II drive from ******, couple of years ago established it was faulty and had a replacement sent.
only this one is doing exactly the same as before.
if im playing games or running applications the hard drive does not cut out make any sounds, its nice and happy
same applies if im defragging it.
Soon as i try and open or install a large file such as applications or extracting compressed files.
i hear an eery clicking voltage sound and then the computer cuts out.
i've checked my power cables and HDD cable, i've even ran a diagnostic check on the hard drive and to no avail established exactly what's wrong.
specs
Antec 300 Three Hundred Case
OCZ Stealth XStream 700W PSU - 120mm Fan, 4x 12V Rails
Sapphire HD 5870 1GB GDDR5 Dual DVI HDMI Display Port PCI-E Graphics Card
Asus P6X58D-E X58 Socket 1366 Gigabit Lan Tripple PCI-E 8 Channel Audio ATX Motherboard
Intel i7 930 2.8GHz Socket 1366 8MB L3 Cache Retail Boxed Processor
G-Skill 12GB (3x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V
Western Digital WD5000AAKS 500GB SATAII 7200RPM 16MB Cache - OEM Caviar Blue
pretty sure, i have ran a stress test on my GPU, CPU and motherboard and RAM and neither have caused the computer to cut out, it's only when my computer tries to gather or touch a large file and physically install it on the the hard drive i get a shut down.
I have physically checked all power cables (unplugged,checked and plugged back in)
this could be a ridiculously stupid statement to make but is there by any chance, that the processor and RAM loading the memory transfere, that quick, that the hard drive physically can't keep up and causes a crash and boot?
It just appears that way when it happens, i can play games at the highest settings doesn't happen it's as soon as i try unloading or installing something onto the hard drive that's a big file (1gb upwards) that causes a reboot.
These are all the error dumped files i picked up I've tried to convert them using the bugcheckcode but I'm not getting anything specific to the problem unless anyone else knows how to do it properly.
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
- EventData
BugcheckCode 30
- EventData
BugcheckCode 10
BugcheckParameter1 0x97401e1
BugcheckParameter2 0x2
BugcheckParameter3 0x1
BugcheckParameter4 0xfffff80002f7967e
- EventData
BugcheckCode 30
- EventData
BugcheckCode 0
I completely reformatted the computer previously with the new hard drive so in theory i started afresh.
The problem only really happened after i installed all my drivers/software for the components (up to date).
It's completely random which makes it more difficult to pin point what exactly are the causes, it could reboot, i can go back to that exact installation and it will not drop out on me.
I'm not running any overclocks on my computer at the moment, i intend too, but not until i fix this problem.
I've changed the Sata ports and HDD cable this morning, so I'm waiting to see if it happens again, touch wood i hope not.
I'll also plug it into it's own power cable tonight and run some more tests at random see if i have solved my mysterious issue.
So far so good, I've actually changed the HDD ports on the motherboard, so the hard drive is booting from a secondary port, i did some tests again i unpacked 10 folders and installed their contents and removed them over and over again and the problem hasn't popped up.
So I'm now thinking the port was possibly faulty but the only way to establish that is by linking another hard drive and repeating the process. However, that's another kettle of fish.
I cleared all my event logs and error messages to establish any new ones popping up.
Good news is none so far, better news no Kernel-Errors, and shut downs so I'll see how far i can go.
Bad news though, now steam has given up on me, and wont establish complete integrity of any of my games, all ways seems to be one file missing, completely unrelated to my hard drive problems i hope.
Appreciate the input and help though guys, lets hope its a permanent fix. :)
