Hard drive clicking and CRC errors.
31 Oct 2004
Harrogate, North Yorks
Tuesday night I was happily playing a game when all of a sudden I got a BSOD... hmm strange I thought. Tried to reboot and just got faced with a message similar to 'insert a bootable media and press any key to continue' straight after post :( . My conclusion was dead hard drive (250GB Samsung Spinpoint, years old). So I managed to recover the files from it using a bootable Linux CD and put all my files onto my 500GB spinpoint.
Now lurking in the draw I had another identical 500GB spinpoint which I bought from someone on the MM well over a year ago, barely used at that point and said to be pulled from a working machine (long term member, no reason to distrust him). I decided now was a good time to use it and promptly installed Windows 7 onto it. All seemed fine until I started hearing a weird "clicking" noise and the system hanged for a few seconds before carrying on as normal. Now any time I try to do something with a big file (anything over ~1GB) the clicking noise starts and the system hangs until it stops. I also tried to run a self extracting 2GB file and it comes up with a 7-zip CRC error. Not getting any other crashes or bad behaviour though and the drive runs smooth and quiet 99% of the time.
Is it looking like this "as new" hard drive is actually a dud from the beginning? :( . I can't blame the guy who sold it to me as it's probably been sat around for about a year and a half but I need to know whether to replace it.
Thoughts?
Edit: forgot to mention I ran a checkdisk and it DID come up with some bad clusters that were supposedly fixed but the clicking persists.
Tried the Samsung utlity, burned to a CD and it wouldn't work for some reason. Something about not being able to load a driver?
Am installing windows on the other 500gb drive and backing up all my files as a precaution.
You might need to switch the sata mode in the bios from ahci to ide for the dos based disk app to see the hdd.
The click of death is definitely the signal to backup your data, perform disk scanning and instigate RMA.
