Not something that I have looked into I admit.
I have a Lian Li PC343B build which has no 3.5" drive bays and requires 5.25" to 3.5" bays or some other form of method to hold drives.
I need to house two 150GB raptors, and was wondering how you guys would go about it?
METHOD ONE:
The old school method of using elastic, which will suspend the hard disks and have in front of them a Lian Li bezel + fan.
+'s:
No vibration carried from disk to case
Cheap
-'s:
Won't solve drive noise, i.e seek noises.
MEHTOD TWO
Nexus DiskTwin, which is basically two metal strips with fins cut into them. They are lined with anti-vibration rubber and also rubber blocks where you screw into from the chassis.
+'s:
Minimal vibration carried from disk to case
Cheap
Look good
-'s:
Again, won't solve drive noise, i.e seek noises.
METHOD THREE
Some sort of disk enclosure. Must have SATA data connection and also SATA power molex connection. The ones I have seen always seem to fall short on one of these things.
So need to be:
Black
Sata data connection
Sata power connection
+'s:
Solves drive noise
Minimal vibration from disk to chassis
Look good
-'s:
Not as cheap (but money is no object)
Anyone know of any enclosures which meet the criteria?
What would you guys go for out of the three options?
METHOD ONE:
+'s:
Cheap
-'s:
MEHTOD TWO
+'s:
Cheap
Look good
-'s:
METHOD THREE
So need to be:
Black
+'s:
Solves drive noise
Look good
-'s:
