- 7 May 2013
Hi,
Hoping someone can help me here otherwise I've lost a load of stuff
Basically I was working and had a video playing at the same time, the video kept stopping/repeating and I assumed it was VLC player. After closing/restarting a few times it eventually locked windows explorer and I had to reboot. Took a bit longer than usual booting up but eventually got into windows, the samsung magician tool popped up and the drive was missing. Checked in the bios, not showing there either. Swapped it over to a new sata port and same thing. Takes ages booting with it attached then eventually gets into windows and doesnt see it. Not in disk management either.
The drive is a WD 3tb one, model - wd30ezrx-00dc0b0. Not had it for more than 5 months. Am I looking at a dead drive here? Not sure what else I can do to be honest. Guessing if its dead all my data is gone? Luckily I have dropbox/creative cloud both set up to sync my work which thankfully saved but I've got loads of other stuff on it that I'll be gutted if its gone.
Any advice would be very much appreciated.
Thanks,
Ash
Thanks,
Ash
