Hard Drive failing?
14 May 2009
Hampshire
Evening all,
I've been downloading some things from iTunes and I noticed when I tried to play some games that it took forever and in some cases it would never load.
Checked Task Manager and the Disk Usage for D:\ (Where I store my Games & iTunes) is pretty much at 100%.
If I stop the download then it goes back to 0%.
I loaded just the game and the same thing happened with 100% usage.
Tried just loading Rollercoaster Tycoon 2 which is a old game and should not take up 100% disk usage but it does!
Is this a sign that I should consider getting another hard drive?
One step ahead ;)
HDTune stats look pretty normal. Have you checked the stats in Resource Monitor with iTunes running/downloading and idle?
Switching SATA cable is a good one to check too.
