Hi guys seem to be having problems with my hard drive.
HGST 500gb 2.5 sata drive.
Was fitted in my Macbook but failed on me, so i have removed it and installed another hard drive. Decided to run various tests with it plugged into my external housing and ran a complete scan using drive genius 3. This came up with no errors.
But when i go to drive information it shows this.
Display Name: UNTITLED 1
BSD Name: disk1s1
Drive Title: APPLE HD D HTS547550A9E38 Media
S.M.A.R.T.: The S.M.A.R.T. service is not supported by this disk.
Whole: No
Leaf: Yes
RAID Slice: No
Writable: Yes
Mounted: Yes
BSD Major: 1
BSD Minor: 5
Block Count: 976,534,720
Block Size: 512 bytes
Size: 499.99 GB (465.65 GiB, 499,985,776,640 bytes)
Formatted As: MSDOS (FAT)
Volume Block Count: 15,262,080
Volume Block Size: 32,768 bytes
Volume Size: 499.99 GB (465.65 GiB, 499,985,776,640 bytes)
Unique ID: D8ED-1CED
Journal: None
Used: 3.54 MB (3.38 MiB, 3,538,944 bytes), 0%
Available: 499.98 GB (465.64 GiB, 499,982,237,696 bytes), 100%
Number of Files: 0
Number of Folders: 0
Connected Via: USB
Removable: No
Ejectable: Yes
Content Hint: DOS_FAT_32
Content: DOS_FAT_32
Now it says BSD major 1
BSD minor 5
So if these are in fact faulty sectors or what not why does it not show these in the scan?
Also the drive is hit or miss whether its found on disk utility when it was inside the Macbook.
Any way of fixing this or is it for the bin, thanks.
BSD Name: disk1s1
Whole: No
Leaf: Yes
RAID Slice: No
Writable: Yes
Mounted: Yes
BSD Major: 1
BSD Minor: 5
Journal: None
Number of Files: 0
Connected Via: USB
Removable: No
Ejectable: Yes
Content: DOS_FAT_32
BSD minor 5
