Hard Drive Gets Repartitioned??
17 Mar 2003
St. Helens
A friend of mine recently asked me to look at his computer, as one of his hard drives started to show as 40GB and unformated, even tho it was a 300GB. (within windows)
Upon closer inspection, and the same thing happening to other hard drives in his system, it appears that after some restarts, any one hard drive in the system becomes re-partitions as 40GB unformated and the rest of the hard drive unallocated.. this is not just happening to the internal ATA/SATA drives but to USB hard drives which are plugged in as well.
Does anyone have any ideas what could cause this.
You need to give us a bit more info;
What OS + Service Pack?
What filesystem are the patitions?
In Disk Management what other partitions can you see on the disks?
Athlon 64 3.4Ghz
1GB RAM
Windows XP SP2 (all latest updates)
Internal
1x Maxtor 40GB (windows installation, NTFS)
1x Maxtor SATA 160GB (NTFS)
1x Maxtor SATA 300GB (NTFS)
External
3x 300GB USB2 Maxtor Hard Drive
In Disk management they all show as partitioned and healthy, until a restart, in which case... it will randomly choose an hard drive, and it shows one as being partitioned 40GB primary unformatted and the rest of the hard drive as unallocated..
I have done the usual reformat, checked all cables etc... checked all motherboard settings etc
During a restart will all show only 40GB partitions or is it random?
Can you access the dodgy 40GB parition and read/write to it?
Does a restart then restore the full partition?
I've used dozens of internal and external disks and never seen anything like you describe, has me confused.
Whats the PSU like?
Could be not enough juice or mobo perhaps.
my dfi decided to quit using LBA modes a while back and of course windoze said umm would you like to format now! WTF!!
Anyways just a thought :)
