Hard drive help please
13 Aug 2011
Today I cloned my existing 320GB laptop hard drive to a larger 1TB hard drive using Macrium Reflect.
I've now installed the cloned 1TB drive into the laptop and booted it only to be presented with the below screen which disappears automatically after around 10 seconds and the laptop boots normally into Windows.
My questions are:
1) Does my laptop have a 32GB SSD as well? If so, is Windows booting from the SSD / is Windows installed on the SSD as well as the 1TB hard drive?
2) How do I bypass the attached screen?
Many thanks
your sata ports are set to raid mode,set them to ahci
then that screen wont popup
and also set the samsung as first boot device in bios or put it to the top of the list
EDIT: did that screen always appear? even before cloning? if it did its normal if your caching (and no the os will be on the hdd,caching will use the small ssd to speedup the hdd) ignore what I posted above,just do that if the msg wasn't cropping up before
