Hard drive mounts
17 Jun 2005
Kegworth
Hi all.
I've just bought a new sata 1tb hard drive.
I open my Fractal case to find that there is only one hard drive cage-thing. I'm not sure of the correct description but it's the white fabricated metal part with once the HHD is secured to it, allows the drive to slide into the cage in the case. It clicks and secures in place.
Where can I get these from?
Do I actually need to use one? Or can I simply sit the hard drive inside my case?
