Hard drive Problem
26 May 2012
Hard drive Problem
I recently bought a hard drive for my desktop. Just tried to install windows 7 ultimate on it, it is a 160GB HDD, not a lot but can do for the moment, then when I get to the install stage of choosing the HDD to install windows too.. It shows 125MB, I am like? Hang on why is this happening, If anyone knows the fix, please give me a reply, thanks.
maybe a duff drive? What filesystem is it formatted as? It is normal to have a separate 100mb partition on a drive after installation because windows will put its system files there unless you tell it otherwise, but that wont be the case if we are talking pre installation
