If you have a spare IDE connector on your mobo then yes you can.
I would however advise against using the hdd as a slave to an optical drive - esp writer as I believe there to be problems not only in hdd's working slower than optimally when used like this, but also writing to optical media not being 100% - maybe some one else can confirm or deny this.
You could use it as a second drive, but I would be more inclined to buy an external enclosure for it and use it via a USB of firewire port, will give you a nice amount of external storage for backup.
I dont doubt it will work - however I wouldnt advise using it if you dont have to, hard discs have been known to slow down with an optical drive on the same channel
