Hard Drive set up for AVCHD
27 Aug 2007
I am thinking about upgrading my hard drives as I have bought a Panasonic SD100 AVCHD camcorder.
My set up on Intel ICH9R:
2 x 150gb Raptor Raid 0 - OS, Games & Apps
Read Speeds (mb/sec)
Min 90 - Av 130 - Max 160 - Burst 106
4 x 250gb Western Digital Caviar SE16 Raid 0 - Video data & music etc
Min 102 - Av 138 - Max 158 - Burst 128
1 x Seagate 1TB 7200.11 (On Jmicron) - Back up for Video data & music etc
Min 50 - Av 87 - Max 109 - Burst 96
Would you recomend me changing any drives? The WD 250gb are the oldest. Do I even need to change HD are they limiting me in anyway?
I'm not sure what you want to know. The camera appears to shoot a maximum bitrate of 17Mbit which is 2.1MB/s and stores it to SD. The very fastest and latest Sandisk SD cards read/write at 30MB/s and with most cards you'll get a small fraction of that. When it comes to editing because you're not dealing with raw footage you're fine also.
I am asking if by changing any of my HD's for example replacing the 250gb WD for say 320gb Samsung F1's if I will see any benefit when editing video's or would that just be a waste of my money.
It'd be a waste with that camera. I'd look into consolidating a bit though, your RAID arrays are dated and really unimpressive when you consider that the 7200rpm 7200.12's can do just under 110MB/s average.
As a general piece of advice when it comes to video editing you generally want the source files on a different disk to the output files. That way you don't end up having the drive heads bouncing all over the place reading and writing to the same disk.
