Hard drive showing full when it's not
26 Aug 2009
My wife's laptop has a ~200gb SSD in it, the partition is ~200gb usage is showing 99%
I tried various ways of checking for the culprit, and ended up with WinDirStat which confirms about 90gb space usage based on folders
The windows/installer folder accounts for about 60gb or data, programs and documents are not considerable. Windows cleanup only offer minimal space recovery.
I cannot see where the other ~110gb is coming from
Windirstat is useful but I find it has limitations
It doesn't account for my restore points
Or actually my recycle bin either
So it says 40gb used but windows says 60gb used
I find software called folder size more useful
And as said look for hidden files/folders
Had it once my antivirus was creating a huge dump file
Which was hidden
Every time I freed up disk space the file grew and filled the space
Thanks for help,
It led me to google search 'windirstat hidden files' - and I tried treesize instead.
Treesize showed a folder c:\system recovery\ which was about 120gb in total - it does not show as a hidden file in c:
If i delete all restore points, the folder is unaffected, it may be Dell related.
I then found a CMD tool and registry file to add a 'take ownership' context menu - it's running now to grant control over the system recovery folder files recursively.
Then I will delete them all...
Take ownership is really useful
Though it won't deal with 100% of files
Windows.old folder being 1 example it will still leave a few files
But for the most part it will be fine and give you ownership
