Silence is hard to achieve with a mechanical drive, but you can do things to reduce the noise and vibrations. For example mounting the drive on elastic to isolate it, that way the vibrations it produces don't get transferred to the case. Plenty of products on the market, but I'd suggest getting some industrial elastic (don't use elastic bands, they don't do well in a warm/hot computer case and easily snap).
think a lot of hard drives suffer clicking noises after been first installed then re-installed (maybe in same place, maybe in a different place) as it's back in november you bought it i'm unsure to whether or not the manufacturer would accept a return on it but it's always worth contacting them and seeing what they say, if they just fob you off then you could break it and just return under the years warrenty lol
Scan it with Hitachi tool to make sure it is ok. If you don't want to waste a CD on a single tool, get the Ultimate Boot CD. Very useful testing software collection: http://www.ultimatebootcd.com/download.html
do a google images search on 'bungee mod spcr' for loads of other examples
You usually need an enclosure to stop the seek noise.
The two I've used are below (GUP on the left and silentmaxx on the right)
The GUP will keep and old raptor quiet
I'm pretty sure I won a hard drive mount that claimed to increase cooling and decrease noise at a lan last year. Can't remember the name/make/brand or anything (as I thought it was a bit of a gimmic) but I'll post the details of it when I get home/if I can find it.
Thanks
Turns out my dad has a spare bungee net in the garage so I'm gonna cut that up and try it tomorrow.
Should I do a mini build log/ beginners guide type of thing?
soft mounting works really well for reducing seak noise, i can barely hear my hds accessing, while its very noticeable on my dads. different cases, but the real difference is the mounting, his screw in old style, mine are in a antec case with the silicon gromit/washer thingies
Your not supposed to block the air holes in HDD's are you? Which is effectively what these enclosures do isn't it? I'm considering the GUP but this concerns me, that and the price, damn.
