Hard Drive Stress Tester
HD Tune is just a benchmark not a stress tester.
I found a 300gb HD on my shelf which I think I may have taken out of an old pc to upgrade to a 500gb (when I only had space for two drives). Its also possible its broken, it appears to work but I want to make sure before I put my data on it.
Prime95 tests the cpu to failing point
memtest tests the ram to failing point
Just want to do that with a hard drive... surely im not the first? But there is not a lot out there.
Just out of interest, why would you want to stress test a HDD?
If you think it is faulty you need to run the manufacturer's diagnostic utility on it. :)
I have run WD Diag and Scandisk both come back ok, so it looks like it was removed due to lack of space.
Thanks guys.
