I can't touch the side of my drive cage so am I tinkering on the edge of failure...
Some of my disks run cool at 44C but most are idling at 57C is this safe ?
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hdb
/dev/hdb: ST3300831A: 57�C
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hdc
/dev/hdc: ST3160023A: 58�C
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hdd
/dev/hdd: Maxtor 6L300R0: 56�C
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hde
/dev/hde: ST3120024A: 56�C
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hdf
/dev/hdf: ST3200822A: 44�C
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hdg
WARNING: Drive /dev/hdg doesn't appear in the database of supported drives
WARNING: But using a common value, it reports something.
WARNING: Note that the temperature shown could be wrong.
WARNING: See --help, --debug and --drivebase options.
WARNING: And don't forget you can add your drive to hddtemp.db
/dev/hdg: WDC WD1600BB-00FTA0: 53�C or �F
root gw:~/tmp/hddtemp-0.3-beta15> hddtemp /dev/hdh
WARNING: Drive /dev/hdh doesn't appear in the database of supported drives
/dev/hdh: Maxtor 6G160P0: 44�C or �F
