- 30 Sep 2009
- Beccles, Suffolk
Hello, think my hard drive may be about to go please advise.
Samsung F2 i use as a backup drive is connected via sata using a hot-swap caddy so i can take it out when i dont need to use it.
However when i try to transfer files from it it goes from nothing to really slow to nothing. I can still view the pictures etc on the drive just unable to transfer from it. Tried a different drive in the caddy and it works fine then tried a different sata cable and port and the same thing.
I need to get some files off the drive, has anyone got any suggestions to what i can do
