okay i made a puter for my boss.
ga7va xp ultra main board
but the wd 800 (80 gig) harddrive keeps making the noise like the arm is resetting itself.Then the computer freezes.As it should.
Sometimes it boots into windows fine,then will freeze,some times the thing says its booting from cd( which is the last setting, bios wise that i had it on?????)As it wont recognise the hard disk.
My question...is this a faulty harddrive
a power supply issue
or is there some sort of bios setting that ive missed.
Ive just updated the bios,and so far so good(as it hasnt happened yet)
what do you think?What is making the drive arm reset and how to stop it
Thanks
Thanks
