Hard Drives and Heat
19 Mar 2004
Bristol
Quick question...
If I have 3 hard drives is it going to be alright to have them stacked pretty much all on top of each other? Using a Lian Li V1000+ and the only space available is the one drive cage at the bottom behind the fan. I know people say be wary of heat and all that, but is it something I should be concerned about in reality?
No Raptors. A Maxtor 300 GB drive and two of the new Seagate 320 GB drives. I'm guessing the heat of a drive is at least in someway related to how much it's being used and mostly the two Seagates are just going to be storage.
Well they will be in a drive cage designed to hold harddrives. Also they are right behind a fan which is the main thing. I'd say put them in and use something like speedfan to monitor the temps for a few days. As long as they don't go over 40 degrees or so you'll be more than fine. I have 4 harddrives including a raptor crammed into the bottom of a p180 and they never go over 37 degrees.
Hudzy said:
Quick question...
They'll be fine in there. I'm running 8 in the bottom of a V2100+ with an Akasa Amber in front of them, currently the disks in the rear stack are running around 39C.
That's good news then. Might pick up one of those Ambers, if I can run it faster and at the same noise as I currently do then it has to be an improvement. I run the fan the case came with at slowest speed at the moment for noise reasons.
