Hard Drives Disconnecting due to Sata Power Splitters
22 Oct 2012
Basically my problem is that Windows will no longer boot when I have all my hard drives plugged in.
My Setup
My setup is explained below:
I have a 520W Seasonic Platinum SS-520FL2 FANLESS Power Supply, 80PLUS Platinum, Fully Modular, EPS 12V ATX. I have a Core i7 2700K and a basic graphics card installed. I have the following connected to that:
7 Seagate Archive 8TB internal hard drives.
2 SSDs
2 Bluray Writers
The following is how everything is connected to the power supply. All the cables came with the PSU so I thought I was supposed to use them?:
6-Pin outputs to 4-Pin Molex Socket A. Molex Connected to Socket A is connected to C Drive Sata power. Molex Socket A also splits to Molex Socket B.
Molex Socket B also splits into Molex Socket C. Molex Socket C has a molex connected to it to power 2 case fans.
Molex Socket B has a molex connected to it. This splits into 2 Sata power connectors. Each is connected to 1 ( Silverstone ) 4-In-1 SATA Power Connector. These have capacitors inside them. 4 8TB Seagate Archive hard drives are connected to one of the Silverstones and 3 drives are connected to the other one.
I have another 6 Pin connected to the PSU. This time it's a one piece cable. It has 4 sata power connectors on the end of it. I connected my 2 Bluray drives and SSD Data drive to it.
Problem
I do a lot of heavy video encoding all day long. My problem is that after about 1 month of usage of everything I mentioned above, Windows will no longer boot. It says select the proper boot device. I then disconnected 1 of the 8TB drives from the 4 way Silverstone. It booted again. Next day I noticed 1 of the 8TB drives I was encoding from just disconnected while the drive window was open. It's not shown in the partitions. So I disconnected another 8TB hard drive. It was working again. For an unrelated reason I restarted my PC and it wouldn't boot again so I disconnected the 2 Bluray drives and it's working again.
I noticed this warning on the Silverstone website: "Warning:Do not use more than four hard drives on one single power cable". So I guess that's my problem? I have a 6 Pin plugged into the PSU which has multiple splits each split is connected to all my hard drives excluding the Data drive.
However that doesn't explain why the one-piece cable conncted to the 2 Bluray Drives and SSD Data drive no longer works correctly. I had been using it fine since April when I bought the PSU but now Windows won't boot unless I disconnect both Bluray drives. I don't think the cable has the big chunky capacitor on the end (if that's what it is), it just has the sata power connectors. So maybe because it doesn't have capacitors that's why Windows won't boot? Doesn't make sense as why would a cable like that come with my PSU if you can't actually use it?
I had been previously using the 4 way splitters with 7 WD Green 4TB hard drives for the past year and I've never had any problems apart from the C Drive issue where you can't use a 4 way with it. I've now replaced all the 4TB drives with Seagate 8TB ones and it's now I'm getting the probems. I've used a power meter and at the moment my PC with everything except 2 Bluray Drives and 2 8TB drives plugged in - I'm using only 144 watts. I would say with those additional items plugged in I would be using around 200 watts. My PSU is rated for over 500 watts so clearly I have enough power to power all my hard drives so what's the issue?
I thought as long as you have enough watts in your power supply you can power any number of drives you want and that splitters are similar to using a surge protector where you can plug multiple plugs into. I guess I was wrong. Does each PSU socket have a limited number of watts it can supply or a limited amount of connections you can connet to it?
Solution?
Any thoughts or suggestions on how to get all my drives working without issues?
I have several 6 pin and 8 pin PSU sockets free. Do 8 pin to Sata power cables exist and if so should I buy those or should I get 6 pin to sata power cables and some Sata power to sata power extension cables so they will reach the drives? Should I get ( single power cables )
or ones which ( split into 2 ) and allow you to connect to drives to them?
Hard drives don't even use that many watts so I don't know why I'm getting these power issues and there's nothing wrong with the drives as they're all new and working fine.
