Harddrive Motor = Dead
21 Sep 2005
Bradley Stoke, Bristol
My 160GB Seagate 'Cuda died last night. Think the motor is shot, drive won't even spin up.
So I've lost all the music and other stuff on it (was a backup drive)
Is there any possible way of recovering the data?
If it was possible to take it apart I might aswell give it a go.... the data is gone otherwise.....
I've checked its not the actual SATA power cable, as My other drives still work fine. Any idaes on a cheap fix? if not how expensive for Data Recovery?
for a physical disk recovery, £100+ probably £200+
not that it matters much, but, It probably isn't the motor as they tend to slow/speed up a bit before dying so you'd see problems before it died completely. Sounds like a lack of power from somewhere...
:eek: :eek: :eek:
Suddenly the idea of writing 50cds back onto a harddrive sounds quite exciting.
Will check all connections again, Looks like I will be making the most of Seagates 5 year warrantee.
thanks for the response though
You could try getting an identical working drive and swaping the printed circuit boards over as it may be a blown chip etc
Very risky business. One in which you risk being left woith 2 dead drives and an empty wallet.
