Installing XP on a second HDD
Hi all,
Can i get xp onto my second hdd, ive tried putting it in and booting from the disk but it says NTLRD is missing.
I was thinking maybe i can install xp when its a secondary drive.
Any ideas?
Thanks.
Please ignore the below [problem solved]
I have two harddrives a 40gb and a 10gb IDE.
Both work ok. (did)
I had XP loaded on the 40gb for ages and was using it fine but today i got some parts and decided i want to installed xp on the 10gb so i can test other bits.
So i put it in my pc as a second drive - put the xp disk in and installed. seemed ok.
untill i turned my pc off and put my 40gb back in by itself.
Booted up and it said it cannot read my hardware configuration.
So i thought great!
Tried the 10gb and now that says something is missing press Ctrl + alt + del to restart.
But..
When i put the 40gb and 10gb in together it boots into the new install (10gb) and the 40gb is showing up and i can see all my files ect.
Hi all,
Any ideas?
Thanks.
Both work ok. (did)
So i thought great!
But..
