NSIS Error
The installer you are trying to use is corrupted or incomplete.
This could be the result of a damaged disk, a failed download or a virus.
You may want to contact the author of this installer to obtain a new copy.
It may be possible to skip this check using the /NCRC command line switch
(NOT RECOMMENDED).
OK
I get this quite a lot when opening a downloaded file, this can be quite frustrating when its a big file.
I had this problem on my last install. Hardrive is 1-2 months old. Always had this. I don't get this problem when downloading via torrent.
On my last install the system32 folder corrupted. Which prompted me to reinstall windows.
I also used a friends disc when installing incase something was up with my xp pro disc.
Any ideas?
