quad any cards isn't a good idea for gaming - you'll be fighting input latency.
Jericho was bleeding like a piggy on the bacon slicer last night![]()
Pros
* The most powerful 3D Card
* DirectX 10.1 support and possibility to add another card
* UVD Inside (Avivo HD)
Cons
* High noise and power consumption at peak
* Small difference compared to a 8800 Ultra
* Few bugs due to internal CrossFire affect performance
Fact is it needs to be cheaper, you can get the exact same in 2x cards.![]()
I would, when you can buy 2x single 3870's cheaper than that that are the same, which is what i would do, i wouldn't care that the X2 was only on 1x PCB, you can get the same card on 2x PCB's, same performance for less.
Seeing these benchies i'm very interested to see the price it comes in at. Whilst it only appears marginally better than 2 3870's in xfire which can be had for £270, and it gets beaten by 2 GT's in SLI which can be had for £310.
Whilst one would expect is to be around the £270 mark, if it approaches too close to the £300 mark then people will just SLI 2 GT's for the same cost and better performance
PCZ, gets the GX2 is 2 GTS's SLI'd which will ofcourse beat this card, but i'd imagine that coming in at the £400+ area so really a different market to this card.
£300, thats a major problem for ATI!
The twin GTs beat the X2, and so you can safely expect the badly named 8 series in disguise 9800GX2 to be equal or better to the GT's, beating the X2. As long as NV dont push the GX2 out at any more than £330ish it will definatley be the better card... that is if people dont just SLI a pair of GTs or GTS's...
Not looking good for ATI...
So the internal crossfire could be buggy killing its performance just like the 2900 and 3870 with AA? Well they cant release it untill they have fixed it then..
