Dear Overclockers, underclockers and hardware guru's.
Here is a brief insite into my computer hardware spec,
mobo: GA-EP35-DS4 (no prizes for guessing manufacturer ~ sorry)
cpu: Intel core 2 Quad Q6600 G0
mem: 4x 1GB OCZ Reaper 1150Mhz
Recently while playing eve-online the eve client would crash to desktop randomly with no error in the eve-logs to suggest it was caused by the client. So i figured it was an issue with windows and so done a re-install. When win7 booted for first time I got a blue screen (didn't log the code) figured it was a hardware fault. So i ran some tests...
Loading the computer up with 'ultimate boot CD v4.1.1 I loaded and ran Memtest86+ v1.70 on each ram stick to 100% pass, all four sticks passed and reported no errors.
I then ran the same memtest with all four sticks of ram and was instantly presented with a huge list of errors from test one onwards.
However when I changed the memory multiplier from 4.00~ to 2.00 I recieved no errors when running the same memtest.
Since changing from the 1066 bootstrapping aka 4.00~ to 800 bootstrapping 2.00 the memory frequency is 667/533 which is low as far as i am aware considering my ram is able to work in excess of 1066 infact it is rated to 1150.
right now a windows pc on stable hardware is needed and if that means running at the lower speeds so be it. however i would like to get this system stable again and running a FSB of at least 1066.
I am confused as to what is actually happening here and would appreciate any help getting this old work horse back up to speed.
Regards
Regards
