Has a cpu ever died on you after so long?
29 Apr 2004
I was wondering if any of you guys have had your cpu die on you and only the cpu.
Since you're able to get used cpu at around 60% of the new price it would be worth it if cpus last long.
Thanks
me
Been PC'ing a loooong time and never had a CPU die on me yet*. There again, I don't push my CPU's like some of the guys on here! I'm sure someone somehere may have fried a CPU by overcooking it! Also worked in IT Support and never came across a dead one in a business environment. Have known some people who have unintentionally damaged them though. Seen a couple fried by people not aware of good ESD practise, seen a couple with pins bent by ham-fisted assembly, etc.
*Just remembered, had one go me, not by overheating though...I had a cheapo PSU die on me and take out everything in my PC except the motherboard and sound card. CPU, hard drives, graphics card, 2 optical drives, all fried. :( Oh, the smoke...at least when my Hiper 580 decided to go nuclear, it only took itself out!
Thanks
me
Nope, never.
I've broken a couple of old AMD's when slamming heatsinks down on them but never had one fail from 'use'.
Sounds interesting as someone mentioned a Q6600 going for £90 on the mm, sounds like a bargain especially as cpus tend to last for ages, maybe even forever (probably not :rolleyes:)
only chip ive killed from overclocking was a celeron 3.2 775 we used it on a vapa chill unit, was fun for a while and then it died. :)
Nope. never. Even pushed 1.65v through a 3200+ Venice before and ran it 24/7 for a couple weeks.
My cyrix 586 100 Mhz ran at 120MHz for 18 months + ...
My Pentium 120 ran at 133 for 2 years + ...
My first celeron 300a (300MHz) ran at 450 MHz for 6 weeks :eek: The second one lasted longer - 12 months +
My Barton Mobile 2500+ (1.83Ghz) still runs at 2.5GHz :D ... 3 years or so. Was at 2.8GHz whilst under water.
Opteron 165 from 1.8GHz to 2.8GHz still going strong 2 years down the line
There were a few others but no dead cpus other than that one celeron :p
nope not me either and i push them till they cant go no more.
the most beat up chip i had was a 2800xp and i put 2.2v through that to get 2.7ghz out of it lol but it still worked perfectly until i sold it :)
i haven't had a cpu die on my since northwood days, and that was under phase.
i've even sliced 2 caps clean off my opty 148 when removing the IHS and she still went to ~3.5ghz 24/7 stable :)
only thing ive seen is an old 2100+ t-bred. it was run at ~2.2-2.4v for 2.4ghz for 3 years and now wont post with sub 1.8v. still runs fine however....
I've never bust one.
I was given an old AMD machine to look at (wouldn't boot) and when I removed the cooler a large chunk of the CPU came with it.
That one was dead ;)
The owner could have done that as he had been messing with it.
out of all the cpu's ive had in the past, the only thing that happened to one of my chips was that it only had half the cache it should have had, it was like half of it burnt out or something.. it even read that way in CPUZ
If its a GO then £90 is a steal but it is more than likely a B3
As for CPU dying nope never
P166
K6 200
K6 400
AMD 1200
Barton +1800
Venice 3000
X2 3800
And now I have a Q6600 waiting to be built, I have just realised that this will be my first Intel chip for about 12 years
