- 8 Jan 2009
- Northern Ireland
What it is, when I switched on I was getting a solid amber light, my system revs up for a second then power's off, then it repeats its self. so I removed all my card and memory to see if there were broke. I have noticed that when I remove the power cable for my CPU, then the system fans will work, but, if I reconnect the power cable, then they wont work, and the system power's on and off every second or two.
