has my pc died on me?
21 Jul 2022
UK
was running some apex with a friend the other week when my pc just switched off initially thought the power in the house went but realised it was just my pc. Unplugged it all took it outside and dusted the inside wiped it down etc. when i went to test it i plugged the power cable in and switched it on and got a red light on the mother board i think (will double check) the pc doesn't turn on just a flashing red light when the power is on.
pc specs:
Cooler Master Hyper 212X CPU Cooler
Asus TUF Z270 Mark 2 Intel Z270 (Socket 1151) DDR4 ATX Motherboard
Kolink KL-600 600W 80 Plus Bronze Power Supply
Samsung 250GB 850 EVO SSD 2.5 SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250BEU)
Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Intel Core i7-7700 3.6GHz (Kaby Lake) Socket LGA1151 Processor - Retail
Corsair Carbide 270R Mid Tower Case - Black Window (CC-9011105-WW)
Asus GeForce GTX 1060 Dual OC 6144MB GDDR5 PCI-Express Graphics Card
4TB HDD
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
The only changes from when i bought it was an additional ssd and the 4tb hdd swapped in for a 2tb that became faulty.
I was wondering if i should send the pc to get fixed as i am not the best when it comes to PC building etc.
Any help would be appreciated ty.
The red light is coming from the motherboard but im unable to see exactly where as the graphics card is sitting infront of it, as stated above when i plug in the power cable and switch on the power from the back it starts flashing quite slowly but consistently flashing and i cannot switch the pc on
PSU or mobo are the most likely faulty components. The easiest way to test is to swap in a known working psu but I guess you do not have a spare to do that.
If the gpu is faulty you can remove it and plug the monitor into the mobo video output and see if you can boot with the integrated graphics. This is unlikey and the psu or mobo most likely at fault.
Afraid i can say the psu is the culprit. My friend went for this psu and 1.5 years later the pc started repeating your symptoms. After i told him his psu is the issue and was able to repeat the issue when ever he put the gpu under heavy load he finally got a new 650w, corsair rm650 and 2 years later is still running as it should ;)
Unless I'm reading the whole thread wrong the OP doesn't have the symptoms of when under heavy load ,it just doesn't boot up . It could be the PSU but then it could also be another component.
Same issues, pc just turned off for no reason while gaming. Was unable to boot into windows with an amber led under ram. He was able to get it to boot into windows the following day. Leaving it over night fixed the issue to allow windows boot, but under heavy load the psu shut the pc down again and repeated this symptom. Thinking ram was the issue and turned out to be a psu over current protection.
