So to clarify, you think Prime 95 has the same AVX 2.0 routines as the two latter tests? This place has really gone down hill.
Maybe this will help:
http://www.overclock.net/t/1510388/haswell-e-overclock-leaderboard-owners-club/2390#post_22900116
Well of course it does, there's only about a dozen AVX extensions. Linpack is even used as an example benchmark in this Intel AVX white paper. I get the impression more and more that you're blagging TBQH.
http://www.intel.com/content/dam/ww...on-e5-v3-advanced-vector-extensions-paper.pdf
Regarding that forum post, an Asus marketing rep spreading rumours about competing software to the benefit of their own Realbench software isn't exactly a convincing source.
I can overclock about 2-300mhz more in general if I ignore the Elephant in the room that AVX 2 prime can't pass but I don't.
This is a good way to put it.
It's like ignoring 50-70% of a CPUs performance (from AVX extensions) just to get a few hundred MHz more overclock.
The real "problem" here (from an overclocking point of view) is these chips get hot when used to their full potential. I don't know if it's the transistor density or the die-IHS interface or something else, but there's no way around it. The solution isn't to stick your fingers in your ears and say you don't like this or that program, it's to back off a few hundred MHz and test again. Saying it's "unrealistic" is a cop out.
