iPhone 3/3S where the battery pack swelled and popped the rear case off when left in a drawer unused for a few months?
The iPhone 4 which was released with Apple knowing that large, sweaty hands in physical contact with the antenna caused it to de-tune significantly causing dropped calls and loss of service? Not to mention the first iOS fix to change the algorithms for how cellular service was displayed in the wake of Antenna Gate were FUBAR’d and service indication only changed when the phone camped on a different cell.
The iPhone 5 which shed anodising and edges as you looked at them if anything harder than an over-ripe avocado came near them?
I’ve never understood why so many people had a problem with signal on the iPhone 4. Much like my old Nokia phones that came with a printed manual that showed you where the antenna location was and advised you not to touch or block that area because it may result in reduced or loss of signal, I simply didn’t touch or block the antenna on the iPhone 4 either.
Here’s the exact wording from the Nokia E71 manual:
‘Your device may have internal and external antennas. Avoid touching the antenna area unnecessarily while the antenna is transmitting or receiving. Contact with antennas affects the communication quality and may cause a higher power level during operation and may reduce the battery life.’
And then there’s a picture which shows you where not to touch.
