Have I killed my computer?
11 Aug 2015
So I added another SSD to my machine, but now it wont boot.
I took the GPU and cleaned it with the hoover then reconnected it. I took out the lead that powers the CPU, tidied it up, then put it back. I took out a data/sata lead from a SSD (which snapped on the lead) so replaced it and reattached. I added another data/sata lead and added the new SSD. Went to boot, but just a black screen. The screen is registering, just showing nothing. Could it be trying to boot from the other SSD?
What've I done?
PS - ignore the shocking cable management.
Depends on the card but the majority require both connectors.
If it was booting from the wrong SSD you would usually still get some form of display.
I did the exact same thing a few weeks back, Must have spent a good half hour scratching my head and I realized I'd not even plugged any power to the GPU :rolleyes:
The dust always has a negative influence because it worsens the contact between fresh air and the metal cooling surfaces, thus worsening the cooling efficiency by a lot.
I find using an air compressor more convenient because it pushes all the dust out and away rather than pulling it inside like when using a vacuum cleaner.
A pc hoover is a thing?
Ive used house hoover in my pc for decades lol.
Same here, been using a hoover and a soft brush on all the inert bits in the case since Noah was a lad. So long as you're gentle on not Edward Scissor-Hands, you'll be fine. Should you feel the need, I think ESpares do a set of micro-nozzles for under £10. You can pick up a soft anti-static brush for few quid.
I am more worried about static
Use a brush to dislodge dust but keep the hoover away from the case and mobo at least
Compressor user here too,i take the case outside and give it a good going over at least once a year.Taking care not to spinup the fans
