was it this 1 from this site?
https://www.less4gadget.co.uk/new-samsung-s34e790-s34e790c-power-supply-adapter--p1841
this the one?Help! Just tried to order one of these as my adapter is on the blink only to get the following response from less4gadget:
"Sorry, we have received complaints about the compatibility of the power adapter you ordered.
So we closed the list."
Anyone found an alternative source?!
You're welcomeGreat spot - thanks! Says it the correct one but doesn't provide a lot more detail. I've asked them to confirm the output V and A to be sure.
Sorry I couldn't find one with UK postageHave ordered
Should be here early next month
I'll keep switching my dodgy one on and off again until it goes completely!
Will post how well it fairs on receipt.
Thanks all!![]()
Help! Just tried to order one of these as my adapter is on the blink only ...
@silvagti That is exactly what was happening to mine before I replaced the power supply (see my post immediately above yours, 23 June 2021). Three months later, the power supply I bought is still working perfectly.
Hello, I am in the same situation with my power adapter on my Samsung S34E790C monitor and was wondering if the "lps-go power" adapter was a good buy or not. Have you had issues with it?just wanted to say thanks for the lps-go power suggestion. My power supply from them arrived last week and it’s working great so far!
Yeah, it and the monitor are still going strong!Hello, I am in the same situation with my power adapter on my Samsung S34E790C monitor and was wondering if the "lps-go power" adapter was a good buy or not. Have you had issues with it?
Many thanks.
