- 27 Oct 2005
I'm having a problem with my comp since a format hoping you guys in here can point something out i've missed
Above is crystaldisk of my two SSD's, they are both OCZ AGILITY 3 drives (less than 6months old)
They are both on the intel sata3 controller
I've installed the exact same drivers I had on before in the exact same order I did before, AHCI is enabled in bios.
The first thing i notice is windoze loading, I never saw the 4 coloured dots before that make the windows logo, now it takes the full logo before it goes onto the desktop.
Secondly I am noticing a little jerking in games
And also a slight delay when navigating folders whereas before it was instantaneous.
There is one thing i cant seem to solve, the IRST service will not start anymore (could be related?)
Are there any thoughts? or tests i could run you guys know of?
cheers
James
System spec.....
3930k @4.8 (formatted at stock speeds)
4x4gb hyperx grey
GA-X79-UD5
7970
1x 60gb agility3 windows only
1x 120gb agility 3 games
1tb storage drive (have tried with this unplugged)
tx750
cheers
James
System spec.....
4x4gb hyperx grey
GA-X79-UD5
7970
tx750
