Permabanned
- 5 Apr 2006
So I recently built a new loop and i'm having trouble shifting a huge bubble that's trapped in the tubing that comes from the CPU block into the top radiator. The bubble goes into the rad when the pump is on but I don't think it goes far as when you turn it off and lay the system on it's side it comes back out again. This is making the system unable to play games as the GPU temp just rises and rises until the GPU cuts out but the system is still running.
I've tried tilting in every direction but it just won't move. So I thought I would just drain the loop and try again, but the loop won't drain.
I've attached a drain port to the inlet of the pump, when I open the tap all it does is empty the reservoir and that's it.
My loop order is as follows res/pump > GPU > CPU > top rad > front rad > res/pump
Can anyone help me?
Can anyone help me?
